- Fri Jul 07, 2006 12:16 pm
#168469
Hi all,
i think it would be helpfull for all of us, and also for Tyron, Miguel and Juan;
if we make a list:
1) with problems that occured to users,
2)with solutions that maybe some others found out,
3) and for the things where we find no solution we should make a "c4d-plug-improvment-wish-list"
4) good things about the new plugin
ad 1):
::i cant render in preview render anymore from plugin, this worked nice in 1.0, now the rendering stays at sl0 adn doesnt date up, the small preview works
:: i cannot put more than one mxm on a selection tag, cinema is able to have more than one tag on its objects,also of the same kind
:: my material tags dont work anymore, i have to manually drag a c4d texture into the maxwell tag- this is an incredible unhealty workflow, it takes hours to texture now my models instead of minutes, and it leads to unnecessary errormessages if you oversee some tags. this was not necessary in 1.0
ad2) no solutions yet
ad3)
:::please give us the streamlines workflow as it was in 1.0 reagrding textures and tags!!!
::: please let us save settings of the plugin into a file, maybe with a dropdown menue to select differetn settings
::: please let us really use selection tags, also with mxms! we cannot use only the 5 premade beta materials,a nd we need to be able to use 2 or 3 materials of the same kind on one object.
ad4)
:: good, it doesnt crash anymore
:: good, animation+ motionblur seems t work(not yet tested)
:: good, no cameratarget is needed anymore
:: good: write mxm
this are the things that come to my mind, i might add more with further testing...
with all respect to the nextlimit team, i really do hope that there is the will to give us an improved version of the plugin(it needs a still some improvments), i hope you hear us users too.
thanks & cheers,
stefan
lllab
if we make a list:
ad 1):
ad3)
ad4)
:: good: write mxm
thanks & cheers,
stefan
lllab
- By Lucas Macabéo
