By insomnia3d
#168422
Finally after many Changes here the lenghtiest interior i have ever done and the buffer project from Brasil to Maxwell....
Not great but it is a beguining, i should of started with a simpler scene.
By x_site
#168528
that's pretty good work!!!
By misterasset
#168533
That's not good work, that's GREAT work. Way to go. After seeing this a few times over in the other section of the forum it's impressive to see how far it's come.
How did you do the people? Are they poser models or are they some "low-poly" people from a store. They look great.
By GM5
#168554
Nice job insomnia3d :!:
-Greg
By Leonardo
#168637
Now we're talking!! great work...
Hopefuly you learned a few things a long the way :wink:
leo
By JTB
#168661
Great work!
One thing though, it seems that the people are not so clearly textured
Is it because of low res images?
By insomnia3d
#168744
Thank you all for the coments. After so long of a pesimistic output on this learning curb it really counts a lot. I think we all deserve a pad on the back for the wor we are producing thanks to NL.
misterasset - They are AXYZ_DESIGN people. Not to great when it comes to close up but they are coming out with some high res models that should really do the trick.
Leonardo- More than what i bargained for.... :shock:
JTB - The folder has HI-Res which are the ones i use, but they still look as you say... hopefully i'l have better lwo poly from AXYZ
I still need to get a hold of the ambient light and the noise level. Hopefully once i'm able to use V1.1 it will be solved.
THANK YOU ALL AGAIN.
By yadikrisnadi
#168850
Thats very nice images, are you using noise reducer? The images so soft.
Cheer,
Yadi
By Xlars
#170955
Beautiful work
By insomnia3d
#171356
Just Photoshop...i haven't even tried motion blur..
