- Thu Jul 06, 2006 6:05 pm
#168124
if you hit the render button in cinema and nothing is happen :
first kill or delete you old custom mxm tags (if you add them with an older plug in version 7b or 7b )
this should correct this problem !
2.dont forget to change you working folder in the plug in menue
cos cinemaxwell dont change it.
3.also the render szene name,before you overwrite you last work (mxs)
i hope this helps !
i hope this helps !
Mac Pro 2 x 2 QuadCore 2.26GHz ( "Nehalem" ) /12 GB Ram /ATI Radeon 4870.
/Software :Newtek Lightwave 10/ Pixologic ZBrush 4/ Luxology Modo 501 & Imagesynth 2/ Uisoftware "Artmatic Pro 4.8" & Artmatic Voyager
