#161097
I try to export an archicad model by using dwg. i like to open it in rhino.
the problem is that some blocks and some xrefs aren´t exportet. rhino trys to open them from the "reference".dwg, but it only works with some objects(xref/blocks). is it possible to put blocks and xrefs into the model as real existing models and not as references? Does anyone knows what a AcDbPoint is and how i can select it in Acad?
