- Fri May 26, 2006 9:21 am
#157056
I wish that the MXCL, triggered from MAX render plugin, would tell you when it is going to overwrite the file in the Output Image Settings/Image space. Also it seems to default the last path used if you do not set a path under the Render Output Sequence area under the Renderer pop up in the MAX plugin. I hope that was clear enough. I keep overwriting good files with all the testing I have been doing, which is a pain when it takes 12-14 hrs to get a "great" noise free image.
Regards Peter.
Regards Peter.
- By jack marvia
- By Mark Bell
