- Fri May 19, 2006 4:55 pm
#155296
Dear users,
Rhinoll plugin 1.0.0:has been released:
- Fog removed from the interface (no longer supported)
- Latitude/longitude synchronized in Environment dialog (confusion) - latitude is first...
- HDRI file dialog contains proper file filter (mxi, hdr files)
- HDRI "Use Sky" renamed to "Disable" - consistent with Studio
- HDRI channels are enabled by default
- Object names are correctly exported to MXS (name appended by the "serial number" of the object)
- Material names are correctly exported to MXS
- If the material name is not changed while editing it no error dialog is displayed (material with the same name exists)
- Support for named views - named views are exported to MXS as individual cameras
- Alpha channel is disabled by default
- Date settings are correct - wrong date was passed in the case of physical environment
- Polygonal diaphragm for camera - angle and number of blades is used properly
Juan
Juan
Next Limit Team
- By Maxwell Team
