By victor
#154518
* build 114
· Fix: crash with no surfaced polygons. Now a default material is applied.
· New: Holes supported
* build 112
· New: n-polygons supported. Holes do not work.
Polygons are internally triangulated and send to Maxwell, so there is no need to triangulate before any more. Note that holes are still not working so you might need to triangulate them previously in such case.
· New: support for .mxi files in the LW luminosity channel (doesn't render in viewport)
The .mxi format is accepted as a valid image format in the Luminosity channel, but it is not displayed. We only use it a a reference to create a MXI emitter.
· Fix: avoid crashes with points and segments
Single points and segments are ignored. This was causing annoying crashes.
