By juan
#152599
Hi quatto,
can you post any image showing this issue?
quatto wrote: also im not sure but if i use physical sky and sunlight, can i not use interior emiters ? it looks like they cancel each other. is that true ?
You should be able to use all of them at the same time, there is no cancelation between them. So you say that you render the scene fine but if you enable the sun the emitters turn black?
I encourage you to post both questions in the main forum, you will get response faster, a lot of users are using ags with sucess.
Regards,
Juan
