- Fri Apr 28, 2006 11:02 pm
#146253
I can't get a decent strength bump just by adding a cinema shader to an object (along with a maxwell mat such as plastic) even when i set the strentgh to several thousand - see image 1
On this 2nd image i used a custom mxm and added the bump in the bump channel of the maxwell material manager and i managed to get it working ok
but is there a way to get a decent strength bump by just using a maxwell plastic for example (not a custom shader) and a cinema mat with the map in the bump channel of that instead?
Cheers, Ric
Cheers, Ric
