By Tyrone Marshall - Thu Apr 27, 2006 6:03 am
#144266
Maxwell Render for Cinema4D Public
Software Issue Reporting Process:
1 - Please ensure that your problem is not already known
because it may have already been solved. Please use the
forum search tools first to check to validate that your problem is
a unknown issue report.
2 - Please verify you are using the current plugin and render
engine version.
3 - Any registered user of the Cinema4D plugin on the
Maxwell Render forum can submit a issue report by posting a new
thread with the following information as a suggestion:
-Operating System and Version
-System hardware
-Description of situation in which the problem occurred
-Can the problem be reproduced in a certain way?
-Provide Rendered Images to illustrate problem if possible
-Provide archived MXS file and any bitmaps if possible
-Report one unique issue per thread
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=4126
4 - Please allow Next Limit to research and evaluate your issue
report in a timely manner. A priority will be assigned to your
issue report and any additional information will be communicated
either via Next Limit or through the forum moderator handling
issue reports as soon as possible.
5 - Please understand that your report is in the process of
evaluation, no further action is required of you.
6 - Forum Moderator handling issue reports will update the issue
report sticky as issues are solved and fixed.
7 - Your efforts to help identify problems in the software are
appreciated. A solution to your inquiry is on its way!
Current Issue Reports:
Current Plugin Version: Cinemaxwell 0.7c
PC.......Version: Released 04-26-06
MacOS Version: Released 04-26-06
Issues Solved: All solved issues relate to previous plugin
version issue report index. Use the links below when you see
(Version *.*) below for a solved issue to get back to the reference links.
Previous Plugin Version: Cinemaxwell 0.5
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=4110
Previous Plugin Version: Cinemaxwell 0.6
ref: http://www.maxwellrender.com/forum/view ... 2860#42860
Previous Plugin Version: Cinemaxwell 0.6b
ref: http://www.maxwellrender.com/forum/view ... 3363#43363
Previous Plugin Version: Cinemaxwell 0.6c
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=4723
Previous Plugin Version: Cinemaxwell 0.7b
ref: http://www.maxwellrender.com/forum/view ... 5677#95677
0.7 Series Solved Issues:
Issue: C04: OSX Alpha channel Crash (Version 0.7b)
Issue: C05: OSX Zbuffer channel Crash (Version 0.7b)
Issue: N10: OSX Install Initialization (Version 0.7b)
Issue: N12: MXCL Viewer Render Channels Not Created (Version 0.7b)
Issue: N14: OSX Custom MXM Not Working (Version 0.7b)
Issue: N16: OSX Write Error From Plugin When Changing Scene Name (Version 0.7b)
[Critical] Issues
C01 OSX Update C4D crashes on next start if maxwell dialogue saved in layout [Critical]
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=3294
C03 OSX Update C4D crashes when texture applied to luminance for emitter object [Critical]
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=5128
[Grave] Issues
None to report.
[Pending] Issues
P01 KNOWN Motion Blur [Pending]:
P02 KNOWN Plugin parameters for animation [Pending]:
P03 KNOWN MacOSX "Command Line" options inoperative [Pending]:
P04 KNOWN Polygon Selection tag for multimaterial [Pending]:
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=2334
P05 KNOWN M~R Dialogue Parameters not saved in C4D file [Pending]:
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=2245
P06 KNOWN -Awaiting Retest Propagation to child objects [Pending]:
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=2312
http://www.maxwellrender.com/forum/view ... 8359#38359
[Normal] Issues
N03 Awaiting Retest SSS Abs/SSS varying values not detectable [Normal]:
ref: http://www.maxwellrender.com/forum/view ... 9119#39119
N04 Sun position and Sun control [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/view ... highlight=
N05 Attribute Manager Scale Multiplier Issue [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=4335
ref: http://www.maxwellrender.com/forum/view ... 7909#57909
N08 Textures Applied to Atom Array Object Not Read by M~R [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/view ... atom+array
N13 Visibility Dots Ignored -Nurbs/Deformers [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/view ... 5658#95658
N15 Nurb Objects do not pass material to child objects [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=9835
N17 Cinemaxwell Plugin rotates scene -90 degrees on export to mxs file format [Normal]:RETESTING..
N18 Render Dots do not propagate when parent is a child of another parent object [Normal]:RETESTING...
ref: http://www.maxwellrender.com/forum/view ... 481#112481
Maxwell Render for Cinema 4D Wish List:
W04 Cinema 4D camera x and y film offset. This is a
feature present in cinema 4d camera, it allows x and y movement
of the camera without distortion or change in perspective view.
ref:
http://www.maxwellrender.com/forum/view ... ilm+offset
http://www.maxwellrender.com/forum/viewtopic.php?t=3370
W06 Maxwell Render Settings controlled from Attributes Manager
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=2342
W08 M~R Dialogue Camera Pulldown Update
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=3472
W09 M~R Environment Object Concept Suggestion
ref: http://www.maxwellrender.com/forum/view ... 0508#40508
W10 Editable Geographical Location & Order Suggestion
W11 M~R Camera Tag Shutter Speed Range Value:
ref: http://www.maxwellrender.com/forum/viewtopic.php?t=3945
W12 Clip Maps should correllate to C4D Alpha Channel:
ref: http://www.maxwellrender.com/forum/view ... 6380#46380
W13 Bitmap Region Render/Render Region Feature
W15 Maxwell-Cinema 4D Physical Sky Integration
ref: http://www.maxwellrender.com/forum/view ... 8686#48686
The index includes links to issue reports found within our Cinema 4D forum.
This will hopefully serve as a easy to find index of user commented issue
reports and wishes as they relate to Cinema 4D plugin. Please
send me an private message if your issue report has not been listed
or information here is in error.
Severity Levels Explanation:
CXX - Critical-----[Crash][Breaks Unrelated Software][Loss of Data]
GXX - Grave------[Incorrect functionality][interface logic][Feature Mostly Unusable]
PXX - Pending---[Known/In progress Fix]
NXX - Normal----[New][Default Severity]
WXX - Wish------[Function Improvement][Missing Feature]
XX - Issue/Bug Assigned Number
Thanks to Thomas An. (Rhinoll Bug List) and Kabe for contributions to the
organization of this report.
engine version.
-System hardware
[Critical] Issues
[Grave] Issues
None to report.
[Pending] Issues
[Normal] Issues
ref:
- By Lucas Macabéo
