- Mon Apr 24, 2006 7:50 pm
#142576
(by Jomaga)
Dear Friends,
This is an example of how Maxwell 1.0 reproduces the reality using few real-world parameters and reducing the setup time dramatically. In this case I (Jose-Martin "jomaga") made some photos of a Cornell box (see below) and tried to reproduce it in Maxwell.
Once I had the geometry ready I spent only 15 minutes setting up the lighting conditions. First for the emitters I used the same real values (watts, temperature, lumen and efficacy). Then I created the wall materials using the same reflectance values that I obtained with the help of my luxometer. Finally I set the camera using the same real values of fStop, ISO and shutter that I used when I took the photo.
I needed some tests to adjust the red and green colors but in fact I got a very good image soon without needing to tweak or guess values for hours. I think the use of real-world values is one top end benefit of Maxwell for an architect like me.
Best regards,
A-Team Laboratories®
MAXWELL RENDER 1.0
15-min lighting setup test
Dear Friends,
Best regards,
MAXWELL RENDER 1.0
Next Limit Technologies
- By Maxwell Team
