By danhdesign
#11477
Hi everybody,
I have many problems with DOF but i don't know how to turn it off. I try to check off in the small box but it is not change.
Thanks
By Maya69
#11492
what your probleme
post image for explain your probleme
you can't delete dof because maxwell camera is physical model
but try delete in hypergraph the node between maya's camera and maxwell camera
i think your is result is strange !!!
By jakegoat
#11508
danhdesign wrote:Hi everybody,
Thanks
As Maxwell is physically based, you have the option of increasing your lighting levels and increasing your fstop in sympathy. This will reduce DOF.
But I agree with Jep on this thought; I think the main problem people are having with DOF is not building objects to the correct scale and associated bugs. Try scaling your entire scene before scaling your lights' intensity, perhaps?
gl,
jakegoat
By cyberjuls
#11509
the more you open the focus the more you'll get dof. Another mistake is to have bad scale. think of taking a photo of small objects, you have strong dof effects due to the small distance between your subject and the lens. At least shorter then if it was at a bigger scale.
It seems that most people encountering this problem forget to check this fact. Outside this, i personnally love tweaking maxwell units to get a model look or a realistic one.
a+ :wink:
