By goncalo
#112181
THANKS VICTOR
is working i´m already making a render and everything OK
IS RENDERING
I also saw the preview when is rendering is not working
and after hit render in cinema 4D with new plugin
the preview also not working
ONLY IN STUDIO (in yellow)
By laurindel
#112188
what lucky ¡¡¡ how about lightwave plugin?? Some news?? :)
By Carl007
#112200
I hit the render button in the MR plugin window in c4d, and it start.................... Final Cut Pro!!!!!
happens all the time.
Obvious something funny with my computer...
Anyone know how to fix it?
/Carl
By goncalo
#112204
Carl007 wrote:I hit the render button in the MR plugin window in c4d, and it start.................... Final Cut Pro!!!!!
/Carl
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
By zoetropeuk
#112230
Or right click on a .mxs scene and choose "Open With" and the Other. Navigate to your Maxwell folder and choose "Maxwell". You might have to change the pulldown from Recommended Apps to All Apps.
Make sure you check the check box to always open with choose app. If you're still having problems open the console and post the last output to the forum and I'll try and help.
Matt
By Carl007
#112241
zoetropeuk!
THANKS!
Works already!
By Tyrone Marshall
#112271
Please post Cinema4D related plugin problems in the Cinema 4D forum (I am currently tracking all bug related issues) as both windows and mac plugin is developed together.
Anything that relates specifically to Maxwell Render for Mac OS (not the plugin should be fine to post bug related issues as you wish).
