By oskit
#9794
we can take a look on it, in this case I suggest you provide us a little bit more information, and we can try to find the way to do our best for this soft asap.
Regards
Oskit :arrow:
By tjnyc
#9884
How would NL go about creating this plugin for Mirai? There are quite abit of problems. One it isn't written in C/C++ but Allegro CL, so the NL would have to learn to code or bridge their SDK to Allegro CL. Second, the Allegro CL dev kit for which Mirai 1.1 was developed from doesn't exist anymore, an updated version needs to be use and will most likely have incompatibility issues with Mirai 1.1. Lastly, Mirai isn't even available, and it is doubtfull that 1.5 will be available anytime soon.
A plugin could of course be made, but would NL put some much effort and time into one plugin, when the returns wouldn't be worth it.
If you are serious about Maxwell support for Mirai, you should get on Izware to use the Maxwell SDK to create the plugin.
Cheers,
By oskit
#9913
you are right..
in this case, could be the best way, in fact using the SDK, is the way to do all the other plugings connections soon.
Thanks everyone.
Oskit :arrow:
