work fine now
the executable have size of 20mb
# Launch Maxwell Render with the given parameters.
import sys
from PyQt4 import QtGui,QtCore
from pymaxwell import *
import pymaxwell as mw
class RenderScene(QtGui.QWidget):
# RenderScene init method
def __init__(self):
super(RenderScene, self).__init__()
self.initUI()
# User interface initialization method
def initUI(self):
# Create labels
label_input_file = QtGui.QLabel('Input mxs')
label_output_file = QtGui.QLabel('Output mxs')
# Create lineedits
self.edit_input_file = QtGui.QLineEdit()
self.edit_output_file = QtGui.QLineEdit()
# Create buttons
button_in_path = QtGui.QPushButton('Open', self);
button_out_path = QtGui.QPushButton('Save', self);
button_ren = QtGui.QPushButton('Render', self);
button_in_path.setGeometry(10, 10, 60, 35);
button_out_path.setGeometry(10, 10, 60, 35);
button_ren.setGeometry(10, 10, 60, 35);
# Create grid layout
grid = QtGui.QGridLayout()
grid.setSpacing(10)
# Populate grid with the labels, lineedits and buttons
grid.addWidget(label_input_file, 1, 0)
grid.addWidget(self.edit_input_file, 1, 1)
grid.addWidget(button_in_path, 1, 2)
grid.addWidget(label_output_file, 2, 0)
grid.addWidget(self.edit_output_file, 2, 1)
grid.addWidget(button_out_path, 2, 2)
grid.addWidget(button_ren, 7, 0)
# Set main layout with grid above and resize window
self.setLayout(grid)
self.resize(600, 180)
self.setWindowTitle('Render Scene')
# Connect buttons to methods to be called
self.connect(button_in_path, QtCore.SIGNAL('clicked()'), self.open);
self.connect(button_out_path, QtCore.SIGNAL('clicked()'), self.save);
self.connect(button_ren, QtCore.SIGNAL('clicked()'), self.render);
# open scene
def open(self):
filename1 = QtGui.QFileDialog.getOpenFileName(self, 'Open file', 'C:/', filter='*.mxs');
self.edit_input_file.setText(filename1);
# save scene
def save(self):
filename2 = QtGui.QFileDialog.getSaveFileName(self, 'saveFlle', 'C:/', filter='Image file (*.png *.jpg *.exr)');
self.edit_output_file.setText(filename2);
# render
def run(self):
scene = mw.Cmaxwell(mw.mwcallback);
ok = scene.readMXS(self.edit_mxs.text().toAscii().data());
parameters = []
parameters.append('-mxs:' + 'filename1');
parameters.append('-o:' + 'filename2' + '/sphere-render.png');
# parameters.append('-mxi:'+outFolder+'/sphere-render.mxi');
parameters.append('-res:300x200');
parameters.append('-time:10');
parameters.append('-sl:5');
parameters.append('-nowait');
runMaxwell(parameters);
if __name__ == "__main__":
# Create and show application
app = QtGui.QApplication(sys.argv)
window = RenderScene()
window.show()
sys.exit(app.exec_())
import sys
def __init__(self):
self.initUI()
def initUI(self):
# Create labels
# Create lineedits
# Create buttons
grid.setSpacing(10)
# open scene
def open(self):
print(filename1)
# save scene
def save(self):
print(filename2)
# render
def ren(self):
def run_maxwell_render():
parameters = []
parameters.append('-mxs:'+'filename1');
parameters.append('-o:'+'filename2');
return 1;
window.show()
import sys
import sys
import qdarkstyle
from PyQt4 import QtGui, QtCore
def __init__(self):
self.initUI()
def initUI(self):
# Create labels
# Create lineedits
# Create buttons
button_rend = QtGui.QPushButton('Render', self);
button_rend.setGeometry(10, 10, 60, 35);
grid.setSpacing(10)
grid.addWidget(button_rend, 7, 0)
self.connect(button_rend, QtCore.SIGNAL('clicked()'), self.render);
# open scene
def open(self):
inPath = QtGui.QFileDialog.getOpenFileName(self, 'Open file', 'C:/', filter='*.mxs');
self.edit_input_file.setText(inPath);
input = inPath
print(input)
# save scene
def save(self):
outfile = QtGui.QFileDialog.getSaveFileName(self, 'saveFlle', 'C:/', filter='Image file (*.png *.jpg *.exr)');
self.edit_output_file.setText(outfile);
print(outfile)
# render
def rend(self):
ok = scene.readMXS('inPath')
cameraNames = scene.getCameraNames()
for name in cameraNames:
outPath = 'inPath'+'/'+'new.mxs'
print(outPath)
ok = scene.writeMXS(outPath);
camera = scene.getCamera(name)
camera.setActive()
parameters = []
parameters.append('-mxs:'+outPath);
parameters.append('-nogui');
parameters.append('-s:6');
parameters.append('-o:'+outfile+'/m_%camera%.png');
parameters.append('-mxi:'+outfile+'/m_%camera%.mxi');
#app.setWindowIcon(QtGui.QIcon('C:/Users/archi/Desktop/script.ico'))
app.setStyleSheet(qdarkstyle.load_stylesheet(pyside=False))
window.show()
import sys
import sys
import qdarkstyle
def __init__(self):
self.initUI()
def initUI(self):
# render
def rendering(event=None):
print 'Button clicked: event:', event
ok = scene.readMXS('C:/input/maison.mxs')
outPath = 'C:/input' + '/' + 'new.mxs'
print(outPath)
camera.setActive()
parameters = []
parameters.append('-mxs:' + outPath);
parameters.append('-o:' + 'C:/output' + '/m_%camera%.png');
parameters.append('-mxi:' + 'C:/output' + '/m_%camera%.mxi');
# Create labels
label_output_file = QtGui.QLabel('Output Render')
# Create lineedits
# Create buttons
button_rend.clicked.connect(rendering)
grid.setSpacing(10)
# open scene
def open(self):
input = inPath
print(input)
# save scene
def save(self):
print(outfile)
window.show()
self.connect(button_rend, QtCore.SIGNAL('clicked()'), self.render);################################################################
import sys
import sys
import qdarkstyle
def __init__(self):
self.initUI()
def initUI(self):
# Create labels
# Create lineedits
# Create buttons
#button_rend.clicked.connect(rendering)
grid.setSpacing(10)
self.setWindowTitle('Render Scene Views')
self.connect(button_rend, QtCore.SIGNAL('clicked()'), self.rendering);
# open scene
def open(self):
print self.edit_input_file.text()
# save scene
def save(self):
outfile = QtGui.QFileDialog.getExistingDirectory(self, 'saveFlle', 'C:/');
print(outfile)
# render
def rendering(self):
ok = scene.readMXS(self.edit_input_file.text().toAscii().data());
cameraNames = scene.getCameraNames();
outPath = self.edit_input_file.text().toAscii().data()
print (cameraNames)
camera.setActive()
output = self.edit_output_file.text().toAscii().data()
parameters = []
parameters.append('-o:' + output + '/m_%camera%.png');
parameters.append('-mxi:' + output + '/m_%camera%.mxi');
window.show()
print (cameraNames)
camera.setActive() for name in cameraNames:
print (cameraNames)
camera.setActive()
import sys
import sys
import qdarkstyle
def __init__(self):
self.initUI()
def initUI(self):
# Create labels
label_mxi_file = QtGui.QLabel('Output Mxi')
label_img_file = QtGui.QLabel('Output Img')
# Create lineedits
self.edit_mxi_file = QtGui.QLineEdit()
self.edit_img_file = QtGui.QLineEdit()
# Create buttons
button_mxi_path = QtGui.QPushButton('Save', self);
button_img_path = QtGui.QPushButton('Save', self);
button_mxi_path.setGeometry(10, 10, 60, 35);
button_img_path.setGeometry(10, 10, 60, 35);
grid.setSpacing(10)
grid.addWidget(label_mxi_file, 2, 0)
grid.addWidget(self.edit_mxi_file, 2, 1)
grid.addWidget(button_mxi_path, 2, 2)
grid.addWidget(label_img_file, 3, 0)
grid.addWidget(self.edit_img_file, 3, 1)
grid.addWidget(button_img_path, 3, 2)
self.setFixedSize(600, 180)
self.connect(button_mxi_path, QtCore.SIGNAL('clicked()'), self.save1);
self.connect(button_img_path, QtCore.SIGNAL('clicked()'), self.save2);
# open scene
def open(self):
# save scene
def save1(self):
outmxi = QtGui.QFileDialog.getSaveFileName(self, 'saveFlle', 'C:/', filter='Image file (*.mxi)');
self.edit_mxi_file.setText(outmxi);
# save scene
def save2(self):
outimg = QtGui.QFileDialog.getSaveFileName(self, 'saveFlle', 'C:/', filter='Image file (*.png *.jpg *.tga *.tif *.jp2 *.hdr *.exr *.bmp *.psd *.ppm *.pbm *.pgm)');
self.edit_img_file.setText(outimg);
# render
outMxi = self.edit_mxi_file.text().toAscii().data()
outImg = self.edit_img_file.text().toAscii().data()
camera.setActive()
parameters = []
parameters.append('-o:' + outImg);
parameters.append('-mxi:' + outMxi);
window.show()
i remember that i copied _pymaxwell4.pyd and pymaxwell.py from ( maxwell render 4/python/pymaxwell/python2.7) to Python27 folder (/lib/site-packages/pymaxwell)
