- Tue Feb 15, 2011 9:01 pm
#337818
Tip of the Day #14
Today's tip of the day will show you how to blend two different images loaded into the reflectance 0 and 90 slots using the R2 parameters.
Step-by-Step:
1) Load two different images into the reflectance 0 and 90 slots and set the roughness to 50 (you do not turn on Force Fresnel for images)
2) Enable the R2 function with setting at 0 and 50 – this will give a 50% blend between the 2 images.
You can lower the R2 roughness to shift the percentage of blend in favor of the reflectance 90 image – conversely you can raise the R2 roughness to shift the percentage of blend in favor of the reflectance 0 image.
The following image shows the R2 roughness set at 0,25,50,75, and 100 in order.
http://www.spotoarts.com/jason/tipoftheday/tod14.zip
You can also adjust the BSDF roughness which will adjust the blending curve. At roughness 50 the gradient between the two images is linear -- however as you lower the roughness the reflectance 90 image will become more dominant and conversely if you raise the roughness the reflectance 0 image will become more dominant.
Best,
Jason.
Step-by-Step:
Best,
Jason.
My Video Tutorials: Maxwell Render 3 Materials
