By ababak
#383422
While rendering was progressing fine on three computers, I have requested a preview. After getting "preview was sent" on all three nodes I've got this:
Code: Select all
[09/October/2014 10:21:49] Requesting display...
[09/October/2014 10:22:29] Connection for preview reception.
[09/October/2014 10:22:29] Warning: Manager disconnected!
[09/October/2014 10:22:29] ERROR: Error receiving preview data: The remote host closed the connection
The Manager stopped responding. After force-quitting it and relaunching I've got this:
Code: Select all
[09/October/2014 10:25:11] Searching other managers: Binding to port: 45454
[09/October/2014 10:25:11] Searching for monitors: Binding to port: 45457
[09/October/2014 10:25:11] Maxwell manager 3.0.1.3 successfully initialized.
[09/October/2014 10:25:11] Temp folder created in: /var/folders/k6/7sjvr0rd45d7smmy4f0h94zm0000gn/T/mxnetwork/manager_babak-pro.local/
[09/October/2014 10:25:11] Connection with render node enabled.
[09/October/2014 10:25:11] Render Node added to list:
[09/October/2014 10:25:11] Name: 192.168.10.19
[09/October/2014 10:25:11] Address: 192.168.10.19
[09/October/2014 10:25:11] Name: 192.168.10.3
[09/October/2014 10:25:11] Address: 192.168.10.3
[09/October/2014 10:25:11] Name: 192.168.10.10
[09/October/2014 10:25:11] Address: 192.168.10.10
[09/October/2014 10:25:11] ERROR: Rendering process has crashed in node: babak: 192.168.10.3
[09/October/2014 10:25:11] Warning: Render node disconnected: babak
[09/October/2014 10:25:11] ERROR: Rendering process has crashed in node: babak-pro.local: 192.168.10.19
[09/October/2014 10:25:11] Warning: Render node disconnected: babak-pro.local
[09/October/2014 10:25:11] Connection with monitor enabled.
[09/October/2014 10:25:11] Monitor added to list:
[09/October/2014 10:27:11] ERROR: Error in render node: 192.168.10.10! Operation timed out
Now all render nodes are not responding and I have to force quit them. Not sure why this happened but most of the render results have got lost. Local render temp folders are empty on all but one node.
P.S. Maxwell 3.0.1.3 on Mac OS X 10.9.5
