- Sat Aug 02, 2014 1:10 am
#382178
Hello,
SOLVED: edited the license file to match correct address for new computer.
Had to take my main machine in for service. Took my hard drive out of main machine and installed into back-up machine. Boot back-up machine and all is well.
1. Launch Maxwell and it reports:
LICENSE INFO
License found in standard license path : /Volumes/Macintosh SSD/gary/Maxwell/maxwell_license.lic
ERROR: - Error getting license, returned code : License server does not support this product
ERROR: - Maxwell has no valid license.
ERROR: - NO LICENSE PRESENT
2. I run through "maxwell Render License Activator", choose add to existing license. "maxwell Render License Activator" reports a successful activation.
3. Maxwell does not find correct license and reports same as above.
4. RLM appears to be running properly.
5. Mac osx 10.9.4 Maxwell v3.0.1.3
Is it possible that some software is looking for the MAC address of my regular machine or something similar?
Of course I need to run renderings over the weekend— definitely wrong time for my machine to go down!
Any help is appreciated.
Thanks!
Gary
===================== New session opened at 01/August/2014 16:02:23 =====
MAXWELL RENDER (M~R). Engine version 3.0.1.3
(C) 2004-2013. Licensed to Next Limit Technologies
/Applications/Maxwell 3.0.1.3/Maxwell.app/Contents/MacOS/Maxwell
LICENSE INFO
SYSTEM INFO
Num processors: ( logical: 16, physical: 16 )
Maxwell Root folder :/Applications/Maxwell 3.0.1.3
Host ID: 002500f4cde8
Low Priority Enabled
Found 5 procedural extensions in /Applications/Maxwell 3.0.1.3/extensions
MaxwellHair
MaxwellParticles
MaxwellVolumetric
MGrassH
MGrassP
Found 5 geometry loader extensions in /Applications/Maxwell 3.0.1.3/extensions
MaxwellMesher
MaxwellSea
MWObjectAlembic
RFMeshes
RWMeshes
Found 4 geometry modifier extensions in /Applications/Maxwell 3.0.1.3/extensions
MaxwellCloner
MaxwellGrass
MaxwellScatter
SubdivisionModifier
Found 10 texture extensions in /Applications/Maxwell 3.0.1.3/extensions
Brick
Checker
Circle
Gradient3
Gradient
Grid
Marble
Noise
Voronoi
WireframeTexture
Found 7 material modifier extensions in /Applications/Maxwell 3.0.1.3/extensions
AGS
Opaque
Transparent
Metal
Translucent
Car Paint
Hair
LICENSE INFO
LICENSE INFO
Thanks!
Gary
LICENSE INFO
SYSTEM INFO
MaxwellHair
MaxwellParticles
MaxwellVolumetric
MGrassH
MGrassP
MaxwellMesher
MaxwellSea
MWObjectAlembic
RFMeshes
RWMeshes
MaxwellCloner
MaxwellGrass
MaxwellScatter
SubdivisionModifier
Brick
Checker
Circle
Gradient3
Gradient
Grid
Marble
Noise
Voronoi
WireframeTexture
AGS
Opaque
Transparent
Metal
Translucent
Car Paint
Hair
LICENSE INFO
