- Thu Dec 15, 2011 7:13 am
#350641
I have 6 computers hooked up for network render, I try to do a co-op render and the files get sent to all 6 nodes to try and start rendering. the files get sent fine and it says it's starting to preprocess but then a node will have an error and restart the upload and preprocess...rinse and repeat until the node just completely disconnects. when i go check one that disconnected, I see that the network render node program has shut down.
Always three of the computers will work and three will shut down. The three shutting down are never the same, it's completely random. Any idea what is up? below is a sample from the log to show you what's happening:
[15/December/2011 00:03:00] ERROR: Rendering process has failed in node: StaticMachine04: 192.168.1.6
[15/December/2011 00:03:00] Processing cooperative job: 1
[15/December/2011 00:03:00] Sending job order to node: StaticMachine04
[15/December/2011 00:03:00] ##### Processing pending jobs #####
[15/December/2011 00:03:00] ##### Job 1 #####
[15/December/2011 00:03:00] ### Job type: cooperative ###
[15/December/2011 00:03:00] ### Assigned to: any node available ###
[15/December/2011 00:03:02] Render node: StaticMachine01 Job ID: 1 sl: 3.00135
[15/December/2011 00:03:02] Render node: staticMachine02 Job ID: 1 sl: 3.00119
[15/December/2011 00:03:04] Render node: staticMachine02 Job ID: 1 sl: 3.00119
[15/December/2011 00:03:05] ERROR: Rendering process has failed in node: StaticMachine05: 192.168.1.7
[15/December/2011 00:03:05] ERROR: Render node StaticMachine05 has reached the maximum number of failures permitted and it will be closed.
[15/December/2011 00:03:05] Warning: Render node disconnected: StaticMachine05
[15/December/2011 00:03:06] Render node: StaticMachine01 Job ID: 1 sl: 3.00135
