- Thu Aug 11, 2011 7:53 am
#346047
Hi all,
I'm running an animation render via the network job queue which appears to overwrite all files that have frame numbers greater than 9, i.e. frame number 10 overwrites frame 0, frame 11 overwrites 1, and so forth...
It worked fine for a small test render. But now on the final render it takes hours to find out if this will happen again. Has anyone seen this before? This is coming out of Modo (i.e. having saved out one MXS for every frame).
Cheers
- Balt
Cheers
- Balt
