- Fri May 13, 2011 7:19 pm
#342656
Running a homogenous Mac Pro setup, I am having issues with nodes not starting up, or falling off (If I open the Node preferences while running).
I sincerely hope a significant update is on the way to address these stability issues, as this system should be rock solid by now.
All the systems are running the same OS, memory, Maxwell version on a local network.
Things seem rather unstable/inconsistent at the moment.
Thank you,
Rick Eberts
Thank you,
Rick Eberts
