- Tue Feb 15, 2011 12:17 am
#337768
Hello guys,
How Do I check if all is ok?
....2 computers, one with 1 standard license (manager with node also open) an 1 new node license in the second:
1-from Rhino(after set parameters and output path folder/ existent shared folder??? ,...etc) I click "render with Maxwell"....Maxwell Render opens with all the counters that starts and an image is forming
2-...here I click "render/render via network"...also Maxwell Monitor opens... I answer every window with ....cooperative...ok, paths (I confirm),..."start" or "resume"(I don't understand!!!)....and at the end I see a Job with 2 computers "rendering"...this is good!
but...
a- the "display" of Maxwell Monitor doesn't work . Do I have to continue to see the image status and modify the set in Maxwell Render that continues open?
b-How do I put the 4 windows ...jobs, render nodes,...that I have involuntary move, in the default posicion?
c- At one moment in Maxwell Monitor
Job 14,298 SL
comp1 12.219
comp2 12.987
In Maxwell Render 13.00 SL
...that is good? What is the real SL in this moment if I stop?..14...12...13?
the 2 computers works in cooperative?Is it sure that the speed of render has improve respect to the same scene with 1 computer?
Thankyou
rober
but...
Job 14,298 SL
comp1 12.219
comp2 12.987
Thankyou
rober
