- Mon Aug 23, 2010 2:33 pm
#329342
When I am starting Network manager this is happening, sometimes its with nodes too. To be honest after last fresh windows install yesterday (lightwave was not sending jobs to Network Monitor after upgrade to 2.1 and I could not fix it) I have managed to do 1 render and if failed whan merging anyway.
I am in the process of setting up my own network controller but until then I would like to be able to render using my computers, not only locally...
BTW, I am on Win 7 x64.
Code: Select all
...and it goes forever[23/August/2010 13:27:09] Searching monitors: Binding to port: 45454
[23/August/2010 13:27:09] Searching for monitors: Binding to port: 45458
[23/August/2010 13:27:09] Maxwell manager 2.1.0.0 successfully initialized.
[23/August/2010 13:27:09] Temp folder created in: C:\Users\Soth3d\AppData\Local\Temp\mxnetwork\manager\
[23/August/2010 13:27:09] Receiving broadcast from node in port: 64202 at address 192.168.137.106
[23/August/2010 13:27:09] Render Node found
[23/August/2010 13:27:09] Receiving broadcast from node in port: 59410 at address 192.168.137.100
[23/August/2010 13:27:09] Receiving broadcast from node in port: 59720 at address 192.168.137.107
[23/August/2010 13:27:09] Receiving broadcast from monitor in port: 60968 at address 192.168.137.100
[23/August/2010 13:27:09] Monitor found
[23/August/2010 13:27:09] Connection with render node enabled.
[23/August/2010 13:27:09] Render Node added to list:
[23/August/2010 13:27:09] Name: 192.168.137.100
[23/August/2010 13:27:09] Address: 192.168.137.100
[23/August/2010 13:27:09] Name: 192.168.137.106
[23/August/2010 13:27:09] Address: 192.168.137.106
[23/August/2010 13:27:09] Name: 192.168.137.107
[23/August/2010 13:27:09] Address: 192.168.137.107
[23/August/2010 13:27:10] Receiving broadcast from monitor in port: 60968 at address 192.168.137.100
[23/August/2010 13:27:10] Monitor found
[23/August/2010 13:27:11] Receiving broadcast from monitor in port: 60968 at address 192.168.137.100
[23/August/2010 13:27:11] Monitor found
[23/August/2010 13:27:12] Receiving broadcast from monitor in port: 60968 at address 192.168.137.100
[23/August/2010 13:27:12] Monitor found
[23/August/2010 13:27:13] Receiving broadcast from monitor in port: 60968 at address 192.168.137.100
[23/August/2010 13:27:13] Monitor found
Cheers
Tomek
Tomek
