OK, here's a test I ran. This is the log from the server machine that didn't work. The big error, at least in this case seems to be this part
[10/March/2010 13:57:07] [ERROR] MXS file is invalid
[10/March/2010 13:57:07] [ERROR] No error
[10/March/2010 13:57:07] [ERROR] Open MXS File Error: Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\Composite03a.mxs cannot be read.
I've set my temp output folder to Z:\Temp\Maxwell Logs\server which should explain the path in that last error. Immediately afterward I opened up Maxwell Render, opened the MXS and ran a render and it worked just fine doing it that way rather than through the Monitor.
Any ideas?
Here's the full log...
[10/March/2010 13:42:05] Searching manager...
Broadcasting using port: 45456
Maxwell node 2.0.2.0 succesfully initialized.
Temp folder created in: Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\
Receiving broadcast response from manager in port: 53796 at address 10.1.29.162
[10/March/2010 13:42:06] Manager found!
Render node connection to Manager via TCP...
TCP socket to manager connected!
My local name: hbe-vserver1
TCP message from manager received.
[10/March/2010 13:47:29] New job order received
Add dependency: Composite03a.mxs
Dependency added.
Not all the dependencies received, render can't start yet!!
Number of dependencies:1
################# DEPENDENCIES ##################
DEPENDENCY 0: Received: NO
Composite03a.mxs
Connection for scene file reception.
DEPENDENCY RECEIVED: Composite03a.mxs
Scene path: Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\Composite03a.mxs
Time: 10000
SL: 25
Start rendering process...
Maxwell rendering process started succesfully.
Notify to manager dependency was received: Composite03a.mxs
Brodie Geers HBE Corporation
[INFO]
[INFO]
[INFO] MAXWELL RENDER (M~R). Engine version 2.0.2.0
[INFO] (C) 2004-2009. Licensed to Next Limit Technologies
[INFO]
[INFO] C:\Program Files\Next Limit\Maxwell 2\maxwell.exe -mxs:Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\Composite03a.mxs -o:Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\GH_House_Challenge_Model_Composite03a.jpg -mxi:Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\GH_House_Challenge_Model_Composite03a.mxi -s:25 -t:10000 -nowait -node -idcpu:13692 -v:4 -channels:r, -depth:8 -camera:Interior -ml:off -bitmaps:\\ -res:3636x3636 -p:low
[INFO]
[INFO]
[INFO] Num processors: ( logical: 8, physical: 8 )
[INFO] Maxwell Root folder:C:\Program Files\Next Limit\Maxwell 2\
[INFO] Low Priority Enabled
Connected to Maxwell Render process!
Message from render process: engine_version 2.0.2.0
[INFO] Connected to render node!
[INFO]
[INFO] Reading MXS:Z:\Temp\Maxwell Logs\server\mxnetwork\rendernode\Composite03a.mxs
[INFO] CPU ID set by command line: 13692
[10/March/2010 13:57:07] [ERROR] Can't start rendering process
[10/March/2010 13:57:07] Render process failed! Exit code: 1
[10/March/2010 13:57:07] New job order received
Dependency added.
Composite03a.mxs
Message from manager: force_stop_render
[10/March/2010 14:18:25] Render stopped!!
[10/March/2010 14:25:45] Manager disconnected!
[10/March/2010 14:25:45] Searching manager...
Receiving broadcast response from manager in port: 59333 at address 10.1.29.162
[10/March/2010 15:01:51] Manager found!
[10/March/2010 15:04:25] Manager disconnected!
[10/March/2010 15:04:25] Searching manager...
