By Tea_Bag
#186857
Hi all,
One of my recent renders, Comments are welcome! SL18 5hrs
Thanks
Tea_bag
AMD X2 4200 64
2GB DDR2 533MHZ
By deadalvs
#186936
i like the picture, but You could pimp it some more...
proposals:
- model the upper «neck» a little more detailed, there's more volume, as i remember (visible only on the left can)
- add a nice glass with some waterpearls on it... fill it with a volume of sprite and add some bubbles... !
- try a less uniform ambiance. the contrast will profit a lot !
- maybe try a still with more DOF...
has a great potential !!
go on !
deadalvs
By Fernando Tella
#186954
The scene looks very good. There's something worrying in that noise though. There should be no noise at all at SL18. Maybe twicking your materials a bit it gets better; maybe the white is too white...
By Tea_Bag
#187108
@Fernando - Agree bout the noise at SL18 and def will play with the white as it does seem to dominate the scene abit! Thanks for comments
@deadalvs - Wow like your suggestions makes it sound so much better already! def will have a play and see what results I get!
Thanks guys!
Tea_bag
By deadalvs
#187110
You're welcome !
go on !
deadalvs
By JesperW
#187147
The lying down can looks a little like it's floating in the air?
Also, it is open, in which case it will have a dent in the whatever-you-call-it lever that pushes the other-thingie into the can.
By Tea_Bag
#187390
Hey Jesper,
Thanks for you comments - The can does look as if its floating but will play with the camera angles to sort it out! Think im going to go for a closed can render in the next one! :wink:
Thanks again,
Tea_bag
By Tea_Bag
#216336
Hey,
Just an update of my sprite cans. Does anyone know why I have the green tint inside my glass ment to be like water trying to simulate sprite liquid. Help anyone? Im on SL 14 maybe let it cook longer?
Many Thanks
By Tea_Bag
#216348
Yip I think that might be it Ivox3 the liquid modeling! But please can you confirm it my original sketch and mxm are seen below.
The Liquid is in red
By Tea_Bag
#217698
The sprite can has been reconstructed :D Ive taken away the glass and will give it another shot! but first back to the basics! Comments welcome!
Thanks
Tea_bag
Sorry Tea Bag .... I just found your screenshots. The new one looks good ....:)
Yeah ..We can get back into the glass later. Your model still doesn't look right ...... I'll post a wire that might help.
By Tea_Bag
#217708
Thanks Ivox3 :) - Def give the glass another attempt would be boring without it! :) - What you think might be the part of the model that doesn't look right?
Any help will be do if it can improve my model!
Thanks
This part is crucial ......
Texture/finish lost in render.
Anything?
Material preview
Yes, I have set Maxwell for Rhino as Current Rende[…]
Hi, there are two problems in studio - First one t[…]
Hello everybody, we have a problem with the Maxwe[…]
