By fv
#296655
I get weird reflectiions in glass surfaces when 'Transformations" is not on on export to render.
The reflections seem to be projected on curved surfaces instead of the straight geometry that is drawn. When I export with "transformations" things are back to normal. This is when I render straight from SU.
Any help is appreciated. I could of course export with transformations but I wonder if there are other problems to be expected.
Thx Francois
By fv
#296894
solved the problem by changing the material. I used "Sun_Shadows_through_glass". Maybe I changed the setting for that material but it gave me weird effects in terms of reflections. Teh effects changed depending on export with or without transformations.
Things went back to normal with lowgrade glass and regular ags.
Maybe here https://forum.maxwellrender.com/viewfor[…]
Well.....they must have been proven wrong, as it's[…]
the render does not start
Also open the Console and read through it to see i[…]
