By Sheik
#207331
Opening the Browser and Wizards from the SU plugins folder is really slow (caused by Ruby), so you may have to wait a minute. On the other hand it can be the same changes to Ruby and IntelMacs that caused the export problem, and probably also the textures problems.
I posted some texture tips/questions in the previous thread. Did you have time to test if they solve anything?
Instead of opening the Material Editor (MXED includes the browser & wizards) from the SU/plugins menu I open it from the normal start menu. It starts faster, runs smoother, and you can keep it open as you work in SU.
Sheik
By Michel Wuest
#207337
Sheik wrote:I posted some texture tips/questions in the previous thread. Did you have time to test if they solve anything?Sheik
no, not jet. I trie it later. Thak's anyway.
By tok
#207415
Tis is the export result on my machine:
By Jacques
#207459
Michel,
The following worked for me:
Quit SketchUp.
Edit the MaxwellExport.rb file (probably here: /Library/Application\ Support/Google\ SketchUp\ 6/SketchUp/Plugins/MaxwellExport.rb) with a text editor as follows:
Under the section/title 'Open Maxwell Material Editor in browser mode' replace the path '/Applications/mxed.app/Contents/MacOS/mxed -brw' with '/Applications/Maxwell/mxed.app/Contents/MacOS/mxed -brw'
Under the section/title 'Open Maxwell Material Editor in wizard mode' replace the path '/Applications/mxed.app/Contents/MacOS/mxed -wizard' with '/Applications/Maxwell/mxed.app/Contents/MacOS/mxed -wizard'
Save the edited file.
Start SketchUp.
Hope that works for you.
J
By Michel Wuest
#207521
Jacques wrote:Edit the MaxwellExport.rb file (probably here: /Library/Application\ Support/Google\ SketchUp\ 6/SketchUp/Plugins/MaxwellExport.rb) with a text editor as follows:
Start SketchUp.
:D :D :D
Thank's a lot Jacques. The edited "MaxwellExport.rb" file works on my Computer too. Great. You should send the corrected Ruby-Script-File to Maxwell.
And Sheik, the opening-time needs aubout one second !!! (Not a minute, like on your Computer)
Cool, thanks again a lot.
By turgeman
#208341
thanks jacques! i had the same problem.
Haha, thanks.
Hello, I'm still waiting for a solution to the pro[…]
Well.....they must have been proven wrong, as it's[…]
