By pascal@deis.fr
#401191
Sorry for mistake.
Finally, you release the plugin for maya ! Thanks a lot
but...
untill the 4.2 plugin, export was perfect. The 'export all' was working well, exporting exactely what is on the viewport.
Now, we have to select and export selected, this is really annoying and generate a lot of mistakes and loose time
And there is an issue with maya instances :
-when there is hidden instances in the scene, maxwell will render these hidden instances.
Even if these objects are in a hidden or template layer.
Please return to the 4.2 export system ! I don't understand why you changed that. It was perfect...
