Everything related to the integration for 3dsmax.
#396845
We are making some improvements to the plugin for 3dsmax, and we wanted to show them to you.
MXLIGHT
Here are some changes we made to the MxLight object:
Here you can see the MxLight object, with a target and showing different gizmos depending on the type of light selected.
Here you can see more surprises in the MxLight object when you activate "Select and Manipulate" button in Max:
You can resize the area light, change spot highlight and falloff angles and modify the intensity of the light by dragging the new intensity handle!
MATERIAL EDITOR
Please, check this video about some of the improvements made in the material editor. No more freezing when updating the preview, easily accessible preview scenes and preview options per material:
https://drive.google.com/file/d/1LzgO1T ... sp=sharing
VRAY TO MAXWELL SCENE CONVERTER
Here goes another one:
CUSTOM ALPHA CHANNELS
Here is another improvement made to the Custom Alpha channels workflow to make it more Studio style and easier to handle:
Please, let us know what you think.
Cheers!
Fernando
#396872
Thank you Arcmos,
You mean to be able to have like a minimal gizmo that doesn't get in the middle, right? I think that could be nice too.
We have also added this in Select and Manipulate mode (it's an animated gif):
You can resize the Area light and Spot and Projector cones; also, we added an intensity handle, so you can change the light intensity by dragging it; it also shows light's color as a reference.
#396880
No. I mean an arrow (now its just aline) on the light like this:
An example for the checkbox Targeted:
The Gizmo is nice and intuitive and i like the width and height field for the area light.
#396943
Hello,
I added more information in the first post about the new improvements made to the plugin for 3dsmax. This time about the Material Editor.
I hope you enjoy them pretty soon.
Best wishes,
Fernando
#396949
This seems nice...but I would very humbly like to ask when the interface for openvdb for the max-plugin will be fixed. I reported this in the beginning of november and got the answer that this is, indeed, a bug and that it would be fixed in a whole new, completely redone version of the max plugin that you planned on doing.
I would really like this as I have an image I have been unable to finish for nearly 6 months now.
Sincerely,
Ingvar Hulterstrom
#396953
Thank you for the heads-up Ingvar!
I have to say I was not aware of the problem until now. I understand you refer to the problem you mentioned in this post, right?
viewtopic.php?t=45018
I'll check it and notify the developers about it.
For future bugs, I would kindly suggest to report the problems to the support team through your account in the portal; that way you can be sure we read it and notify the developers for them to fix it; we always read and answer all the support tickets we get, but in the forum, some post can go unnoticed. Anyway, thank you again for reporting the issue and sorry for the bug and the inconveniences.
#396956
Yes, but I did, there is a support case (#00018486) about this and that's where I got the answer about you doing a refresh of the 3ds plugin. After this support case it says "resolved", which, in my humble opinion, is not completely correct:-)
Sincerely,
Ingvar Hulterstrom
#396957
You are absolutely right, Ingvar.
I'll let the right people know so that it is fixed.
Thank you for your patience.
Fernando
#397154
Hello, here's another surprise that will be included in the soon to be coming update of the plugin for 3dsmax:
Hopefully, you will enjoy it soon.
Cheers!
Fernando
