End date: May 13
By rodrigonotor
#367106
From maxwell documents:
Navigation
These are the basic functions to navigate in the graphical viewports (Mac OSX users should switch the Ctrl key for the Command key):
* The terms in blue are cinematographic equivalents.
ALT + LMB = Rotate camera around the target origin (Orbit / Fly Around Camera)
ALT + MMB = Pan View (Truck / Boom Camera)
ALT + RMB = Zoom View In/Out (Dolly Camera)
ALT + CTRL + LMB = “Slow-mode” – slowly rotate camera around the target origin.The up/down arrows on keyboard can be used to change how slowly the camera should move in this mode. You can repeatedly press the up/down arrows to adjust, then use ALT + CTRL + LMB.
ALT + CTRL + MMB = “Slow-mode” – slowly pan camera.
ALT + CTRL + RMB = “Slow-mode” – slowly zoom camera in/out.
ALT + SHIFT + LMB = Rotate camera target around the camera origin. (Pan / Tilt Camera)
ALT + SHIFT + RMB = Displace camera origin along the look-at direction. This also moves the camera’s focal point (camera target), along with the camera.
ALT + SHIFT + MMB = Roll camera. (Dutch Camera)
http://support.nextlimit.com/display/ma ... Navigation
Regards
By valdesfernando
#367281
Hi, I did these two images, my inspiration is about the Spanish wine, but I have a dilemma, in the first, you can see the background clearly, but in the other image , I like the idea of winery but the background is lost..
what is your oppinion?
[url=http://www.flickr.com/photos/20443 ... .jpg[/img]
test_07 by valdes_fernando, on Flickr[/url]
test_08 by valdes_fernando, on Flickr[/url]
By dariolanza
#367296
Hello valdesfernando,
Yes, the ceiling occludes the background in the second render, but the most important problem I see is that the ceiling style is disconnected to the background architecture.
I you want to preserve the ceiling, try to create a new one inspired in the Calatrava's structure of the building behind, making your winery a part of the Ciudad de las Artes place.
And take care of the shadows of the family group (father-mother-daughter) which has no contact.
The metals are very cool.
Greetings
Dario Lanza
By dariolanza
#367297
Another suggestion:
In order to mix more closely your structure with the existing architecture, I would replace your bricks (which is a construction element Calatrava never uses) by the white tiles he uses in Ciudad de las Artes (inspired in Gaudi).
Greetings
Dario Lanza
By valdesfernando
#367307
Hello Dario.
Thank you very much for your comments.
I made the change in the structure with something more like Calatrava style and change the bricks by old bricks, I will try with white bricks to see how it looks.
i dont know if i will eliminated the walls and leave it open can be a good idea, i really like how it looks, but the environment is a little lost.
with respect to the shadows of people,i will work them in post-production.
i am sending an image to see you think.
Best regards
test_09 by valdes_fernando, on Flickr[/url]
By novena
#367326
dariolanza wrote:Another suggestion:
Greetings
Dario Lanza
Hi Fernando, when Dario suggestes to use white tiles, I think he means to use pieces of broken tiles instead of brick, that technique is called 'trencadis' (from catalan verb trencar = break), this technique is present in most of Gaudi's work
best
V
By valdesfernando
#367350
i did it, but it doesnt look good.
i am making a new structure just with white concrete and glass, more clean, so lets to see how it looks, maybe i will eliminated all pipes
