By raja
#303770
when animating from rhino plugin, i get incremental file names as follows:
file name_1000._1000.mxs
file name_1001._1001.mxs
but mxcl asks for:
file name_1000.1000.mxs
file name_1000.1001.mxs
so it stops rendering after the first mxs file.
where can i set this right? it was working fine for a few files.
TIA,
raja
#303775
I'm not sure how you're getting filenames that look like that. Could you describe what it is that you're doing - are you using Bongo, or AnimationTools, or?
Thanks...
By raja
#303779
Hi JD,
I'm using standard rhino animation (SetTurnTableAnimation and record animation).
After rhino exports all frames as mxs, maxwell asks "render exported frames now?"
when you click yes, it renders first frame, and cannot find next.
regards,
raja
#303780
I was going to say that I don't understand how you're getting it to do that, but then I figured it out - seems I was using the V5 WIP when I tweaked this routine, because Rhino is generating different filenames in V4 and V5. I'll try to see if I can find a workaround for you.
#303783
On further inspection, it doesn't look like I'm going to be able to do anything about this without recompiling the plugin. What appears to be happening is that Rhino is producing filenames with two dots between the file name and extension, i.e. if you set up an animation to use the output name 'test', in V4, you'll get a bunch of frames like this:
That's what's messing up the plugin, and it looks like V5 does not have this happening. Can you confirm that this is what you see there, just by using Rhino Render to export an animation rather than Maxwell?
By raja
#303788
yep, using rhino render, i get these file names:
recompiling sounds too much for this, one can ofcourse change file names or use command line.
regards,
raja
#303790
Thanks for confirming - I'm going to see if McNeel can fix this for SR6. Would you mind letting me know whether you're using SR5 or SR5b right now? I can't install SR5b to check if it's fixed or not because I want to continue building the plugin against SR5.
By hyltom
#303822
If not too late, use this script. Just change the frame number 36 by the number of frame that you want to render.
I forgot who wrote this script for bongo animation, but it's very usefull and with little bit of modification can work well with the basic rhino animation tools.
! _-Runscript (
Rhino.Command("_Maxwell_BeginAnimation")
For Frame = 0 To 34
Rhino.Command "_ViewNextFrame Frame"
Rhino.Command("_Maxwell_Render")
Rhino.Command("_ClearUndo")
Next
Rhino.Command("_Maxwell_EndAnimation")
#303825
Thanks hyltom, that (which I should have thought of :) ) is a good way to work around this SR5/b AnimationTools issue. I just wanted to make sure though - are you aware that the current plugin supports Bongo with no need for any scripting?
By raja
#303841
aha!
thanks hyltom, i'll give this a try.
its not late, I'm trying to be animation-ready for the next assignment.
regards,
raja
hyltom wrote:If not too late, use this script. Just change the frame number 36 by the number of frame that you want to render.
! _-Runscript (
For Frame = 0 To 34
Next
Haha, thanks.
Hello, I'm still waiting for a solution to the pro[…]
Well.....they must have been proven wrong, as it's[…]
