By Josephus Holt
#322016
I think I've got everything set up right (working on cs4 extended), but when I change the intensity or color (emitter 1) it does not affect the composite render. What could I be doing wrong?
#322034
Brany wrote:You must hide the "Render" layer :wink:
Always something simple ;)...thank you.
On a side note..as has already been mentioned, is there a possibility in a future update to have the emitter layers come in to PS with Linear Dogdge (Add) preset?
This plugin makes me very glad I upgraded to CS4 Extended not too long ago. Very timely and welcome release. Thank you!
By dariolanza
#322073
Hello Josephus,
The automatic conversion to "Linear Dodge" mode is actually included in the code, and should work automatically fine. This is our intention.
But due to a bug in the Photoshop SKD, which doesn't recognizes coded blending modes, it is not working now.
But being already coded in the plugin code, if they fix this SDK bug in CS5, it should automatically work as it is meant to be.
By the way, we have to set it up manually.
Greetings
Dario Lanza
the render does not start
I tried hiding many of the objects in the scene wh[…]
Sketchup 2024 Released
I would like to add my voice to this annual reques[…]
