#379084
I have lit a scene in Houdini and set my ROP to output my mxi and images to the same location. My mxs files are being pointed to a different location though.
So I am exporting my mxs files and rendering them with the maxwell command line, but my images get rendered to the same location where my mxs live. Looks like my output image parameter in my ROP gets ignored.
Is this a bug or am I forgetting something?
This is my command line:
maxwell -frames:18,18 -v:5 -threads:8 -scene:/prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0001.mxs -node
The other thing I noticed also was that none of my textures weren't loaded. When I test my scene rendering from Houdini, it renders properly with all textures, but it doesn't work using maxwell command line. My render log doesn't show any error for missing textures though. Please see the log below
Also:
Is there a command line from houdini to render the maxwell render, like maya has with the line "render -r maxwell"? Or do I need to use the maxwell standalone to render my scenes like I am doing it now?
Thank you very much for your attention
Rodrigo Guimaraes
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]: MAXWELL RENDER (M~R). Engine version 3.0.0.0
maxwell:[INFO]: (C) 2004-2013. Licensed to Next Limit Technologies
maxwell:[INFO]:
maxwell:[INFO]: maxwell -frames:18,18 -v:5 -threads:8 -scene:/prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0001.mxs -node
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]: LICENSE INFO
maxwell:[WARNING]: Using license path with MAXWELL3_LICENSE_PATH environment variable : /ce_apps/Maxwell3.0/maxwell_license.lic.
maxwell:[INFO]: License found in standard license path : /home/rguimaraes/Maxwell/maxwell_license.lic
maxwell:[INFO]: License type: FULL SUITE
maxwell:[INFO]: License name: David Brown
maxwell:[INFO]: Company: Cutting Edge
maxwell:[INFO]: Expiration date: 10-apr-2014
maxwell:[INFO]: Issued by: NEXTLIMIT
maxwell:[INFO]: License checked out from server ID: syd-lic01
maxwell:[WARNING]: License Warning Your license will expire in 21 days.
Please visit your customer portal to renew.
https://portal.nextlimit.com/
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]: SYSTEM INFO
maxwell:[INFO]: Num processors: ( logical: 24, physical: 24 )
maxwell:[INFO]: Maxwell Root folder :/ce_apps/linux/maxwell3.0/
maxwell:[INFO]: Host ID: 00259029ed0a
maxwell:[INFO]: Low Priority Enabled
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]: Found 5 procedural extensions in /ce_apps/linux/maxwell3.0//extensions
maxwell:[INFO]: MGrassP
maxwell:[INFO]: MGrassH
maxwell:[INFO]: MaxwellVolumetric
maxwell:[INFO]: MaxwellHair
maxwell:[INFO]: MaxwellParticles
maxwell:[INFO]: Found 5 geometry loader extensions in /ce_apps/linux/maxwell3.0//extensions
maxwell:[INFO]: MaxwellSea
maxwell:[INFO]: MWObjectAlembic
maxwell:[INFO]: RWMeshes
maxwell:[INFO]: MaxwellMesher
maxwell:[INFO]: RFMeshes
maxwell:[INFO]: Found 4 geometry modifier extensions in /ce_apps/linux/maxwell3.0//extensions
maxwell:[INFO]: MaxwellCloner
maxwell:[INFO]: SubdivisionModifier
maxwell:[INFO]: MaxwellGrass
maxwell:[INFO]: MaxwellScatter
maxwell:[INFO]: Found 10 texture extensions in /ce_apps/linux/maxwell3.0//extensions
maxwell:[INFO]: Brick
maxwell:[INFO]: Checker
maxwell:[INFO]: Circle
maxwell:[INFO]: Gradient3
maxwell:[INFO]: Grid
maxwell:[INFO]: Marble
maxwell:[INFO]: Noise
maxwell:[INFO]: Voronoi
maxwell:[INFO]: WireframeTexture
maxwell:[INFO]: Found 7 material modifier extensions in /ce_apps/linux/maxwell3.0//extensions
maxwell:[INFO]: AGS
maxwell:[INFO]: Opaque
maxwell:[INFO]: Transparent
maxwell:[INFO]: Metal
maxwell:[INFO]: Translucent
maxwell:[INFO]: Car Paint
maxwell:[INFO]: Hair
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[21/March/2014 18:44:27] [INFO]: Reading MXS:/prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0018.mxs
maxwell:[21/March/2014 18:44:28] [INFO]: MXS file read successfully
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[21/March/2014 18:44:28] [INFO]: Rendering animation. Loading frame:18.
maxwell:[INFO]:
maxwell:[21/March/2014 18:44:28] [INFO]: Reading MXS:/prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0018.mxs
maxwell:[INFO]: CPU ID used: 3918
maxwell:[INFO]:
maxwell:[21/March/2014 18:44:28] [INFO]: Checking scene dependencies..
maxwell:[21/March/2014 18:44:28] [INFO]: Dependency found: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/maps/1_dollar/1_dollar_head_color_v01.tif
maxwell:[21/March/2014 18:44:28] [INFO]: Dependency found: /ce_apps/linux/maxwell3.0/materials database/mxm files/Treasure_chest_coin_6542/dirt10.jpg
maxwell:[21/March/2014 18:44:28] [INFO]: Dependency found: /prod/vfx/mcdonaldsloosechange/shots/s010/maps/1_dollar/1_dollar_head_normal_v02.tif
maxwell:[21/March/2014 18:44:28] [INFO]: Dependency found: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/maps/HDRI_bondiSky_small.hdr
maxwell:[21/March/2014 18:44:28] [INFO]: Checking Data
maxwell:[21/March/2014 18:44:28] [INFO]: Loading Bitmaps & Preprocessing Data
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing data.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing scene modifiers.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Loading geometry extensions.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing MXS references.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Pretessellating meshes with displacement.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Initializing data.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing geometry.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing materials.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Preprocessing additional parameters.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Initializing render engine.
maxwell:[21/March/2014 18:44:28] [DEBUG]: Initializing multilight data.
maxwell:[21/March/2014 18:44:28] [INFO]: Starting voxelization.
maxwell:[INFO]:
maxwell:[INFO]: Scene Info:
maxwell:[INFO]: Frame: 18
maxwell:[INFO]: Image output: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0018.exr
maxwell:[INFO]: MXI output: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/pic/s010_coins_v01_t01/010_coins_v01_t01_rg.0018.mxi
maxwell:[INFO]:
maxwell:[INFO]: Geometry:
maxwell:[INFO]: - Num Objects: 8
maxwell:[INFO]: - Num Meshes: 8
maxwell:[INFO]: - Num Triangles: 103910
maxwell:[INFO]: - Num Vertexes: 115256
maxwell:[INFO]: - Num Normals: 114560
maxwell:[INFO]: - Num Materials: 8
maxwell:[INFO]:
maxwell:[INFO]: Camera: Camera_1
maxwell:[INFO]:
maxwell:[INFO]: Render settings:
maxwell:[INFO]:
maxwell:[INFO]: - Engine version : 3.0.0.0
maxwell:[INFO]: - Using RS1 engine
maxwell:[INFO]: - Desired rendering time : 100
maxwell:[INFO]: - Desired sampling level : 14.000000
maxwell:[INFO]: - Using 24 threads
maxwell:[INFO]: - Multilight type: Disabled
maxwell:[INFO]: - Save lights in separate files:No
maxwell:[INFO]: - Motion blur: enabled
maxwell:[INFO]: - Displacement: enabled
maxwell:[INFO]: - Dispersion: enabled
maxwell:[INFO]: - Illumination layers:
maxwell:[INFO]: . . direct layer: true
maxwell:[INFO]: . . indirect layer: true
maxwell:[INFO]: . . direct caustic reflection layer: true
maxwell:[INFO]: . . direct caustic refraction layer: true
maxwell:[INFO]: . . indirect caustic reflection layer: true
maxwell:[INFO]: . . indirect caustic refraction layer: true
maxwell:[INFO]:
maxwell:[21/March/2014 18:44:28] [INFO]: Start Voxelization
maxwell:[21/March/2014 18:44:29] [INFO]: End Voxelization
maxwell:[21/March/2014 18:44:29] [INFO]: Voxelization done.
maxwell:[21/March/2014 18:44:29] [INFO]: Start Rendering
maxwell:[INFO]:
maxwell:[INFO]: Start writing MXI file...
maxwell:[INFO]: End writing MXI file...
maxwell:[21/March/2014 18:44:30] [INFO]: MXI successfully renamed.
maxwell:[INFO]: Start writing image file...
maxwell:[INFO]: End writing image file...
maxwell:[21/March/2014 18:44:31] [INFO]: Benchmark of 614.400. Time: 1s. SL of 1.00
maxwell:[21/March/2014 18:44:31] [INFO]: Time left: 4m28s
maxwell:[21/March/2014 18:44:32] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:44:33] [INFO]: Benchmark of 658.286. Time: 3s. SL of 2.00
maxwell:[21/March/2014 18:44:33] [INFO]: Time left: 8m16s
maxwell:[21/March/2014 18:44:35] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:44:36] [INFO]: Benchmark of 673.477. Time: 6s. SL of 3.00
maxwell:[21/March/2014 18:44:36] [INFO]: Time left: 8m17s
maxwell:[21/March/2014 18:44:39] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:44:40] [INFO]: Benchmark of 713.143. Time: 10s. SL of 4.00
maxwell:[21/March/2014 18:44:40] [INFO]: Time left: 8m14s
maxwell:[21/March/2014 18:44:44] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:44:45] [INFO]: Benchmark of 784.103. Time: 15s. SL of 5.00
maxwell:[21/March/2014 18:44:45] [INFO]: Time left: 8m04s
maxwell:[21/March/2014 18:44:52] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:44:53] [INFO]: Benchmark of 814.979. Time: 23s. SL of 6.00
maxwell:[21/March/2014 18:44:53] [INFO]: Time left: 8m03s
maxwell:[21/March/2014 18:45:03] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:45:03] [INFO]: Benchmark of 859.409. Time: 34s. SL of 7.00
maxwell:[21/March/2014 18:45:03] [INFO]: Time left: 9m12s
maxwell:[21/March/2014 18:45:19] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:45:19] [INFO]: Benchmark of 917.091. Time: 49s. SL of 8.00
maxwell:[21/March/2014 18:45:19] [INFO]: Time left: 7m39s
maxwell:[21/March/2014 18:45:42] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:45:42] [INFO]: Benchmark of 938.988. Time: 1m13s. SL of 9.00
maxwell:[21/March/2014 18:45:42] [INFO]: Time left: 7m17s
maxwell:[21/March/2014 18:46:16] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:46:16] [INFO]: Benchmark of 980.721. Time: 1m46s. SL of 10.00
maxwell:[21/March/2014 18:46:16] [INFO]: Time left: 7m39s
maxwell:[21/March/2014 18:47:06] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:47:06] [INFO]: Benchmark of 1000.571. Time: 2m37s. SL of 11.00
maxwell:[21/March/2014 18:47:06] [INFO]: Time left: 6m48s
maxwell:[21/March/2014 18:48:21] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:48:21] [INFO]: Benchmark of 1025.090. Time: 3m51s. SL of 12.00
maxwell:[21/March/2014 18:48:21] [INFO]: Time left: 5m24s
maxwell:[21/March/2014 18:50:12] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:50:13] [INFO]: Benchmark of 1038.959. Time: 5m43s. SL of 13.00
maxwell:[21/March/2014 18:50:13] [INFO]: Time left: 3m32s
maxwell:[21/March/2014 18:52:59] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:52:59] [INFO]: Benchmark of 1052.486. Time: 8m29s. SL of 14.00
maxwell:[21/March/2014 18:52:59] [INFO]: Ending render process..
maxwell:[INFO]:
maxwell:[21/March/2014 18:52:59] [INFO]: Rendering animation. Loading frame:18.
maxwell:[INFO]:
maxwell:[21/March/2014 18:52:59] [INFO]: Reading MXS:/prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/mxs/s010_coints_v01_t01/s010_coins_v01_t01_rg.0018.mxs
maxwell:[INFO]: CPU ID used: 11706
maxwell:[INFO]:
maxwell:[21/March/2014 18:52:59] [INFO]: Checking scene dependencies..
maxwell:[21/March/2014 18:52:59] [INFO]: Dependency found: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/maps/1_dollar/1_dollar_head_color_v01.tif
maxwell:[21/March/2014 18:52:59] [INFO]: Dependency found: /ce_apps/linux/maxwell3.0/materials database/mxm files/Treasure_chest_coin_6542/dirt10.jpg
maxwell:[21/March/2014 18:52:59] [INFO]: Dependency found: /prod/vfx/mcdonaldsloosechange/shots/s010/maps/1_dollar/1_dollar_head_normal_v02.tif
maxwell:[21/March/2014 18:52:59] [INFO]: Dependency found: /prod/projects/mcdonalds_lcm_bundles_mar14_20140/shots/s010/maps/HDRI_bondiSky_small.hdr
maxwell:[21/March/2014 18:52:59] [INFO]: Checking Data
maxwell:[21/March/2014 18:52:59] [INFO]: Loading Bitmaps & Preprocessing Data
maxwell:[21/March/2014 18:52:59] [DEBUG]: Preprocessing data.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Preprocessing scene modifiers.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Loading geometry extensions.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Preprocessing MXS references.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Pretessellating meshes with displacement.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Initializing data.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Preprocessing geometry.
maxwell:[21/March/2014 18:52:59] [DEBUG]: Preprocessing materials.
maxwell:[21/March/2014 18:53:00] [DEBUG]: Preprocessing additional parameters.
maxwell:[21/March/2014 18:53:00] [DEBUG]: Initializing render engine.
maxwell:[21/March/2014 18:53:00] [DEBUG]: Initializing multilight data.
maxwell:[21/March/2014 18:53:00] [INFO]: Starting voxelization.
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[INFO]:
maxwell:[21/March/2014 18:53:00] [INFO]: Start Voxelization
maxwell:[21/March/2014 18:53:01] [INFO]: End Voxelization
maxwell:[21/March/2014 18:53:01] [INFO]: Voxelization done.
maxwell:[21/March/2014 18:53:01] [INFO]: Start Rendering
maxwell:[INFO]:
maxwell:[21/March/2014 18:53:02] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:02] [INFO]: Benchmark of 614.400. Time: 1s. SL of 1.00
maxwell:[21/March/2014 18:53:02] [INFO]: Time left: 4m30s
maxwell:[21/March/2014 18:53:04] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:04] [INFO]: Benchmark of 658.286. Time: 3s. SL of 2.00
maxwell:[21/March/2014 18:53:04] [INFO]: Time left: 8m20s
maxwell:[21/March/2014 18:53:06] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:07] [INFO]: Benchmark of 673.477. Time: 6s. SL of 3.00
maxwell:[21/March/2014 18:53:07] [INFO]: Time left: 8m18s
maxwell:[21/March/2014 18:53:10] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:11] [INFO]: Benchmark of 713.143. Time: 10s. SL of 4.00
maxwell:[21/March/2014 18:53:11] [INFO]: Time left: 8m15s
maxwell:[21/March/2014 18:53:16] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:16] [INFO]: Benchmark of 784.103. Time: 15s. SL of 5.00
maxwell:[21/March/2014 18:53:16] [INFO]: Time left: 8m05s
maxwell:[21/March/2014 18:53:23] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:24] [INFO]: Benchmark of 814.979. Time: 23s. SL of 6.00
maxwell:[21/March/2014 18:53:24] [INFO]: Time left: 8m05s
maxwell:[21/March/2014 18:53:34] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:35] [INFO]: Benchmark of 859.409. Time: 34s. SL of 7.00
maxwell:[21/March/2014 18:53:35] [INFO]: Time left: 9m15s
maxwell:[21/March/2014 18:53:50] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:53:51] [INFO]: Benchmark of 898.931. Time: 50s. SL of 8.00
maxwell:[21/March/2014 18:53:51] [INFO]: Time left: 7m40s
maxwell:[21/March/2014 18:54:13] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:54:14] [INFO]: Benchmark of 938.988. Time: 1m13s. SL of 9.00
maxwell:[21/March/2014 18:54:14] [INFO]: Time left: 7m17s
maxwell:[21/March/2014 18:54:47] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:54:48] [INFO]: Benchmark of 971.598. Time: 1m47s. SL of 10.00
maxwell:[21/March/2014 18:54:48] [INFO]: Time left: 8m02s
maxwell:[21/March/2014 18:55:38] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:55:38] [INFO]: Benchmark of 1000.571. Time: 2m37s. SL of 11.00
maxwell:[21/March/2014 18:55:38] [INFO]: Time left: 6m46s
maxwell:[21/March/2014 18:56:52] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:56:53] [INFO]: Benchmark of 1020.681. Time: 3m52s. SL of 12.00
maxwell:[21/March/2014 18:56:53] [INFO]: Time left: 5m19s
maxwell:[21/March/2014 18:58:44] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 18:58:45] [INFO]: Benchmark of 1035.943. Time: 5m44s. SL of 13.00
maxwell:[21/March/2014 18:58:45] [INFO]: Time left: 3m15s
maxwell:[21/March/2014 19:01:32] [INFO]: MXI successfully renamed.
maxwell:[21/March/2014 19:01:33] [INFO]: Benchmark of 1048.371. Time: 8m31s. SL of 14.00
maxwell:[21/March/2014 19:01:33] [INFO]: Ending render process..
maxwell:[INFO]:
maxwell:[21/March/2014 19:01:33] [INFO]: Render finished successfully
maxwell:[21/March/2014 19:01:33] [INFO]: Ending Session...
maxwell:[21/March/2014 19:01:33] [INFO]: Closing socket..
Finished /usr/local/muster6/ce_run_in_env on syd-render09 with exit code 0
Fri Mar 21 19:01:33 EST 2014
Finished /usr/local/muster6/ce_root_to_user on syd-render09 with exit code 0
Fri Mar 21 19:01:34 EST 2014
[MUSTER]Process terminated with exit code: 0
#379154
Hi Rodrigo,
The path of the output image is set by the -o parameter in the command line. The plugin sets this as well during the render, so the image path is not stored in the mxs scene.
I don't think there's any special settings for the textures, if they are set with absolute path, they should be loaded. Will check this just to be sure.
There's a hscript command to start the render in Houdini:
maxwell_render [maxwell_rop_path] [time] default
The first parameter is the path of the Maxwell Render ROP node in the scene, the second parameter is the time when the render happens, the third parameter is the render mode, which is 'default' for a normal render ('viewport' is an other mode for example). This command will export the scene and run Maxwell Render from the command line, just like you would press the Render button.
Hope this helps,
Peter
