By sam7
#62529
Hey pretty cool!!
Great use of MotionBlur!
How long did the renderingtime need? What sampling level was reached?
Very good !
By thomas lacroix
#62557
the pipe going upward need some smothing, otherwise nice shot!
By nik_h
#62563
Beautiful work Justo! My grandfather used to make model beam engines and similar things from scratch using his trusty lathe. There are still several back home at my parents house.
Could you give some info on the material settings and lighting set-up? It would be really appreciated.
Cheers,
Nik
By Micha
#62624
Very professional work again. :wink:
Only I would try to use less reflection on plastics like the armrest or the wheels (maybe a drak grey could be nice).
You ask for noise and mxi. I have tested a white rectangle emitter and an emitter with a white MXI texture - no difference.
But you get more noise if you use much polygons on the emitter (a problem of MXI spheres) or strong contrast in small details (f. ex. HDRI from a full midday sun or a tunnel HDRI with two bright openings). Better is to use blur HDRIs, if your scene allow it.
Eeeeexcellent! :o
By nik_h
#62697
Thanks for the info Justo - every tip helps! I should be visiting my parents in a few weeks time so I'll take some photos then. Indeed there should be complete sets of drawings somewhere.
Cheers,
Nik
......Tell you what we think????
you know what we think ........it's smokin.....pretty much Maxwell and User at their best ....... tell you what we think (sigh) , you gotta be kidding. :)
well done.
i3.
.......i'll take that. :) nice work.
By x_site
#63183
:: kick ass!!! well the last one is less good than the first ones, maybe the backgroung is too red :wink: ::
By Micha
#63250
Great toy, I want to get one too. :wink:
Suggestion: at the moment I read a photo book and the author write about a object-ground contrast. I feel, in the last image is here a problem. I would try to use a background not in the same color mood like the golden metal and/or let the background be blury per DOF. At the moment, the machine show much details and the background - no detail contrast.
By rivoli
#63273
veery good looking ones. only things i don't like the lighting and reflections in the second image that much, and the chair material might look problably look better with a bit of bump.
