By Olivier Cugniet
#163945
:shock: ..................... :shock: ........................ :shock:
By arch4d
#163948
:shock: is the backgound completely hdri, or some parts modelled ? :shock:
really stunning !
By DrMerman
#163949
Whoa :shock:
By LarsSon
#163952
:shock: I love it!
Just one thing.
What is that dark red area in front of closest finger?
There is some light coming out, but it makes floor look darker.
-LarsSon
:shock:
WOW :shock: very nice Work :shock:
By Jozvex
#164004
Next time I need to buy a robotic hand I know who to call! Really nice work! Blame the bad laser on the assistant engineer, :lol:
Sacré bleu! ! :shock:
#164039
u.biq wrote:It was supposed to be a very powerful zygaLaser, but turned out as a ridiculous splash of red ink :D .
Try modeling a cylinder (I'm assuming the 'wires' are around 3mm diameter) around 2mm in diameter, and as long as you can fit in the finger 'cap'. Remove one end, and invert the normals of the other end, so they're pointing through the resulting tube. Then make the cap a high-powered emitter, and give the tube a pure black diffuse material. Depending on how long you can make the tube, you might need to reduce the diameter to get a focused beam.
Cheers. :)
~JD
well badass... :!:
By aitraaz
#164129
Grand :!:
